So for someone who is more up to speed than I on these things, ie pays attention. I assume the PAC SWI-CAN interface will allow me with some other mechanism translate the CAN bus volume control for the Cayenne into some format that a CarPC can understand?
I see a wired infrared output and surely assume someone has a driver for something like that, but thought maybe there was a stellar integration.
This would allow me to fix the one pet peeve I had with the Cayenne when I drove it. The 1990's sort of Navi screen and interface. Plus modern Google Maps, Bluetooth, and my whole music collection could be had on a cheap Windows 8 machine.
  • Replies 78.9k
  • Views 4.3m
  • jonbearsmt
    jonbearsmt
I would die laughing if you ended up with that.
Lol that doesn't look like your style.
swag
Could be fun to make that change.
J
I would never have guessed the ML is faster in a drag race.
Can't be faster in the corners though can it?
As part of my rear brake upgrade I want to flush the brake fluid on my Jeep, it has abs and i don't have acces to a scan tool. Do i flush it and bleed it normally and not worry about the fluid left in the abs passages? I don't care for the small amount of old fluid left in the abs pump.
I know that if i need to bleed the brakes after working on them i can get away without cycling the abs pump.
I went out for a middle of the night sammich run and the woke my wife up to have a meatball sub at 3:30 am.
:-D
:-D
Where, how, and why do you get a meatball sub at 3:30 in the morning?
Takes a hooker to the supermarket?
Well after reading a bunch I'll just gravity bleed once everything is in place. Going to change the hoses too, 16 year old hoses and fluid...
