  • Replies 78.9k
  • Views 3.4m
  • jonbearsmt
    jonbearsmt
2 hours ago, nem said:
Unrelated I have been looking at garage lightening. I picked up one of these to try and really like the light it puts off. I think 8 will light a 30x40 area nicely.
http://www.samsclub.com/sams/4ft-led-shoplight-shoplight-led/prod16460030.ip?navAction=
That's really cheap!  I'd be skeptical of longevity.  Also, if your ceiling is more than 10 feet, I'd look into doubling them up or something else purposely designed.  LED light diffuses rather quickly or diffracts.  Not sure the proper term here,but as the light gets further away, the less intense the luminosity.
Also, a lot of cheaper LEDs have issues in the cold.  If your space won't be heated, you may have issues in the winter.
Got one for test purposes and will get another for over the work bench, I am going 8' florescent more than likely. Ceiling height is 10'.
As for the guns, I have small hands and a small frame.  The smaller gun only makes sense for me.  Why on earth would I want a larger caliber I cannot control?  Simple physics.
My PX4 grouping is scary after the 3rd shot in quick fire.  I want the rounds nice and tight and all of them on target.  Ballistics data also show the .380 to be just as capable as the larger calibers at close range, making it ideal for smaller people.
Always use what fits, feels, and fires properly for your purpose. Never force yourself to like something.
Hell the most deadly round is a 22LR, it goes in and makes a mess with no exit wound.
Like a pinball in your guts.
If you go that route, I suggest T5HOs.  T8s my be a bit cheaper,but the 5s will last longer and put out the same light using 30% less energy nd the higher voltage HOs will light quick and fully no matter your temp.
We use T5's at work in our buildings and I have been keeping on eye on the fixtures they don't need. Just in the waiting process for approval.
Number One Rule of a Gun Fight: Have a gun
A bullet in the gut is a bullet in the gut
Better a small gun than no gun
plus a bajillion and one other sayings
Indoor of what?
Any thoughts of later buying a 1.4?  Only ask because it would maybe change which 1.8 to buy.
35mm is too wide for portraits and too narrow for wide
50mm is great for face portraits inside, bodies in bigger spaces
85mm is too tight for inside IMO as you will be limited to only faces or similar sized objects without some unnatural distance
You have all the above ranges though.  Shoot at them and compare...pick 3 different targets and use your tripod.
7 hours ago, ///M5 said:
Indoor of what?
Indoor implying closer shots.
Perhaps. Why would it change which to buy?
Didn't think about that.
On 4/30/2016 at 2:55 AM, nem said:
I have been looking for some Polish beer locally and have not had any luck.
I am looking for Zywiec and Lomza, anybody have advice on how I can get some?
I wish I still had some Zywiec from when we visited. I liked that beer lot.
Because grabbing an 85 1.8 for $200 to accessorize a 50mm 1.4 for $250 would be awesome and outside of wide replace your lenses nearly completely
