And I am fat, ugly, poor, uneducated, unhealthy, low on ethical fiber, and only have a 10" dick.
Yet I can't buy a pack of bubble gum without numbing into something that would let me get up in them guts.
  • Replies 78.9k
  • Views 3.9m
  • jonbearsmt
    jonbearsmt
///M5, on 12 Sept 2013 - 08:12, said:
Cablguy184, on 12 Sept 2013 - 08:11, said:
And Randal a 3er can have as much balls as a 5"er, just won't extend is deep moving more of the midbass range to another driver. It will do wonders for your imaging and FR, but if you are stuck with what the sponsors have that obviously won't help.
Its all good brother ... No worries, but If I could see a "midrange driver" like you are referring to dig down and play consistant around 50 to 70 hertz like i have mine set to now, I might would consider it (well, atleast think about it) ...
Ha, no way. They won't but you don't need those freq's up top for imaging.
If they can't handle it, I don't need them then ...
///M5, on 12 Sept 2013 - 08:13, said:
and compared to a proper midbass those 5's don't do shit down to 50Hz, that takes a monster driver at reference levels.
I know Sir ... which is why I bought the best drivers that would work for my application ...
and if I didn't need those frequiencies up there, I wouldn't have made the effort to set it up that way ...
You should do a little reading on vertical imaging cues. It would help you A LOT!
Fuckers at the pharmacy gave me the wrong test strips for my meter.
Everyone wants me to die. People running into me, meds messing with me and now not BG meter.
I'm just gonna go have a jolly rancher YOLO.
2012 Camry. The blend door broke; the one that controls airflow between the heater core and evaporator. The door is internal to the damper servo box, which is mounted to the crash bar under the dash from the backside. The bar has to be lifted up, the box needs to be felt up from behind and the screws removed to take the assembly out of the car. Then the box gets dismantled on a bench even further.
I've never much cared for coffee, but apparently, everything is better Sean's way.
Honestly, I would have liked it to work on my trip to Berlin. Only difference it made was because I moved around and changed the context.
I had the wife's dash ripped apart, not much inside, but a pain in the ass to go that far.
