Posted January 24, 201312 yr I have a 4.1 cubic foot box with a IA DR 15 in it with a round port. It's tuned to 30hz with a 4" diameter and a 10" long tube that come out to 12.5 "sq area.I have not listened to it yet, but is this enough port area?Will it hurt the sub?
January 24, 201312 yr Author I know I fucked up it was my first box but just trying to see if it would still work before cutting a bigger hole and putting in bigger pipe.
January 24, 201312 yr I know I fucked up it was my first box but just trying to see if it would still work before cutting a bigger hole and putting in bigger pipe. No big deal I would just wait until you can put a bigger port in.
January 25, 201312 yr Author How many sq" should I have? Is 20 enough? No, how much power are you running?I can get 29 sq" of port area with a 6" diameter. Only 900wrms running to it so would it matter?
January 25, 201312 yr How many sq" should I have? Is 20 enough? No, how much power are you running? I can get 29 sq" of port area with a 6" diameter. Only 900wrms running to it so would it matter? 29 is still less than I would use but it will be way better.
January 25, 201312 yr Author Could I put a second 3" port?Can't fit another 4, but I could do an 8" with 50sq" area too.
January 25, 201312 yr http://diysubwoofers.org/misc/portcal.htmAbout half way down the page gives a good formula to use to estimate the minimum port area you should have.
January 25, 201312 yr Could I put a second 3" port?Can't fit another 4, but I could do an 8" with 50sq" area too.An 8 would be good if you can make it work.
January 25, 201312 yr Author Could I put a second 3" port?Can't fit another 4, but I could do an 8" with 50sq" area too.An 8 would be good if you can make it work.Yeah, It would be half in half out though.Is 50sq" to much?
January 25, 201312 yr Could I put a second 3" port?Can't fit another 4, but I could do an 8" with 50sq" area too.An 8 would be good if you can make it work.Yeah, It would be half in half out though.Is 50sq" to much?Half in, and half out is fine as long as you calculate it properly. 50 is not too much.
January 25, 201312 yr Author It would look alot better with another 3" though, could I do that?It would be to small I think.Thanks rick. Edited January 25, 201312 yr by daveishome
January 25, 201312 yr Author Do you mean another 4"? Yeah I'm going with the 8" diameter that's 23" in length tuned @33 hz.50 sq" of port should fuckin pound.
January 25, 201312 yr Do you mean another 4"? Yeah I'm going with the 8" diameter that's 23" in length tuned @33 hz.50 sq" of port should fuckin pound.I'm not sure if this is what you are saying but two 4" ports do not equal one 8" port.
January 25, 201312 yr Author haha no 1 8", I will cut my 4" hole to 8, and buy new pipe.I said yeah to the last post, my mistake I'm baked. Edited January 25, 201312 yr by daveishome
