Posted January 26, 201313 yr Would mounting my amp on the same side I mount my woofers cause any problems? I mean that would be the strongest part of the box considering its a double baffle?There's enough space to fit it there so I don't see how it would be a problem but figured I'd post to get input, any possible side affects?
January 26, 201313 yr As long as you put some sort of vibrating suppression under the amp then it's fine by me.I use 34" thick foam under my amp's mounting feet whenever i need to install it on a panel that will be flexing.Make sure you compensate for the screw length because of the padding.
