Planning a build in a 2012 hyundai sonata with the infinity premium system while retaining the stock unit
Here's what we have so far
Hybrid audio clarus
jl hd 600/4 + 750/1
2 jbl gto 12's(IB)
No processing as of yet since the head unit schematic is very tricky.
Now, from the information I've gathered
The stock head unit has a digital out(spdif) that goes to the factory amp.
Usually, you'd go straight from head unit to processor, but, if you bypass the factory jbl amp, you lose bluetooth, xm, & am/fm radio.
I'm about 90% sure the speakers crossed inside the amp, so I'm lost on what to do here.
Tapping after the amp seems like the only option, but I can't seem to find out if the signal is full range or not.
What can I do? Do I just install a processor and hope for the best?
Here's the schematic
can't the jl clean sweep sum the channels?
I believe that you can test the output with test tones and a dmm but I'm not positive. I'm sure someone here can help.
Forgot these existed
Didn't know about this.
If worse comes to worse, Get a cleansweep?
play tones and measure voltage. if there is any filtering the voltage will drop.
