Posted February 2, 201313 yr I am switching sub sizes and I am going from a 18'' to 10''. I have seen people build custom subs with different motors and baskets. now my question is will any basket fit on my motor with out any problems? I have 2 18'' hdc3 audioque.
February 2, 201312 yr Author why do you you wanna build something on that motor ? whats wrong with the audioque motors
February 2, 201312 yr Mounting holes could be different, so "no problem" would depend on your ability to drill & tap new holes if necessary. If you can't do that then you would need to make sure the basket has the same mounting hole pattern.Were you planning to use an AQ recone kit? Not a great idea to build a sub out of random parts like most people do...they think it's "cool" that it's unique but reality is that most of them have no engineering behind them and they have no idea about the actual performance of the subwoofer. Most people with these custom subs can't even tell you what the T/S are.
February 2, 201312 yr Mounting holes could be different, so "no problem" would depend on your ability to drill & tap new holes if necessary. If you can't do that then you would need to make sure the basket has the same mounting hole pattern.Were you planning to use an AQ recone kit? Not a great idea to build a sub out of random parts like most people do...they think it's "cool" that it's unique but reality is that most of them have no engineering behind them and they have no idea about the actual performance of the subwoofer. MOST PEOPLE with these custom subs can't even tell you what the T/S are.And you'll never find 10" frames and soft parts to fit with proper geometry.
February 2, 201312 yr AQ uses 12 spoke baskets on those hdc3s if I'm not mistaken. You really want to stay away from drilling new holes for mouting a TI basket and such, and using a different coil/drop in. Using the same 12 spoke style and the hdc3 recones is ideal for proper functioning of the woofer.
February 2, 201312 yr Author Mounting holes could be different, so "no problem" would depend on your ability to drill & tap new holes if necessary. If you can't do that then you would need to make sure the basket has the same mounting hole pattern. Were you planning to use an AQ recone kit? Not a great idea to build a sub out of random parts like most people do...they think it's "cool" that it's unique but reality is that most of them have no engineering behind them and they have no idea about the actual performance of the subwoofer. Most people with these custom subs can't even tell you what the T/S are. thank you for the help i was just wondering if it would be worth my while to do and the drilling and tapping wouldnt be a problem. As far as the engineering part i never thought about that part of it. If i was to do this i would put a psi recone kit on it. now i will just probably buy some 10'' subs thanks for the help.
February 2, 201312 yr Author AQ uses 12 spoke baskets on those hdc3s if I'm not mistaken. You really want to stay away from drilling new holes for mouting a TI basket and such, and using a different coil/drop in. Using the same 12 spoke style and the hdc3 recones is ideal for proper functioning of the woofer. so if i could find an audioque 10'' hdc3 basket that would be the best way to go and just do a aq recone kit
February 2, 201312 yr AQ uses 12 spoke baskets on those hdc3s if I'm not mistaken. You really want to stay away from drilling new holes for mouting a TI basket and such, and using a different coil/drop in. Using the same 12 spoke style and the hdc3 recones is ideal for proper functioning of the woofer. so if i could find an audioque 10'' hdc3 basket that would be the best way to go and just do a aq recone kit Yes, if they are 12 spoke baskets they are not hard to come by. psi sells them on their site, just do some research and confirm that they are 12 spoke. You probably want to use AQs recones as they will be cheaper and more to spec than psi's recones. But you can do whatever you please to make it work.
February 2, 201312 yr They don't make hdc3 in the 10" model. That would be a problem then. You could go with a 12
February 2, 201312 yr Haha yea it kinda would be. To OP, why do you want a 10 inch now? Are you set on just audioque?
February 2, 201312 yr Mounting holes could be different, so "no problem" would depend on your ability to drill & tap new holes if necessary. If you can't do that then you would need to make sure the basket has the same mounting hole pattern. Were you planning to use an AQ recone kit? Not a great idea to build a sub out of random parts like most people do...they think it's "cool" that it's unique but reality is that most of them have no engineering behind them and they have no idea about the actual performance of the subwoofer. Most people with these custom subs can't even tell you what the T/S are. This is why I asked .
February 3, 201312 yr Author They don't make hdc3 in the 10" model. they made them they just don't carry them anymore
February 3, 201312 yr Author Haha yea it kinda would be. To OP, why do you want a 10 inch now? Are you set on just audioque? the 18's were going to go in my Tahoe and I found a steal on a extended cab truck so I took out the back seat and throw the 18's on there but now I would like to have a back seat again. no im not stuck on aq just thought it would be easier to make them into 10's then sell them or trade them.
February 3, 201312 yr why not just sell the 18s and get your hands on some 10s or 1 12. They do make recone kits for 10" hdc3s
