February 8, 201313 yr ohh ns-1 puts more power out tho at .5 ohm ive got it clamped at 7,128 watts wonder what im putting out at .25 with mine then.... oh and what org. do you plan to compete in?
February 8, 201313 yr Author Heres a little update! new suspension! 1,800lbs capacity for rear and battery bank along with amps and wall should be plenty!
February 19, 201313 yr Good to see you already thinking about suspensions for the car. That should help a lot if you want to drive with all those equipments ! Waiting to see more...pics. Good luck for this build.
March 6, 201313 yr Author Good to see you already thinking about suspensions for the car. That should help a lot if you want to drive with all those equipments ! Waiting to see more...pics. Good luck for this build.thank u kind sir! and yes im planning smart and ahead i want to make sure my car can withstand each and every bit of weight i will put in it. .. so 1800lbs of support is plenty
March 6, 201313 yr Author wow epic build coming along very nice. thanks man!! yeah im really exited about it since i came back from SBN!! i have alot of new ideas for my build so stay tuned!
March 10, 201313 yr Author Guys Build UPDATE!! This Build will have 4 15s!ill think about it and we will see if i can handle that much power other then that heres a Build update we are going full force on this buildhole for 6 frame grounds!! 3 grounds on opposite sides of the frame! Resistance Free!!! 0 volt! grounds are plasti dipped to prevent rust! and corrosion
March 20, 201312 yr Author Heres an update guys! Little Electrical Work 6 Runs off Singer Alt to the rear battery bank!
March 22, 201312 yr Author Yeaaaaaa everybody's building walls TeamFi/AA doing big things.aw pshhh! im building a meefer cabinet ontop of my car...
April 3, 201312 yr Author Update!!False Floor almost done! made it elevated and floating for air cooling and plexi window for my fuse block!!
April 3, 201312 yr Good luck with the build. Definitely looks like a lot of work and it makes my ears hurt just thinking about it.
