Posted February 12, 201313 yr what is the difference between e8v3 and the e10and which should be louder with a 1400 rms rated amp
February 12, 201313 yr E8vs is an 8 inch subE-10 is the bigger 10 inch sub.There are both the same classs of sub, just different sizes.a single E wont take 1400 rms well. There rated at 400 rms3 or 4 might sound allot better on that same amp. a 1400 rms rated amp will tear that sub up Edited February 12, 201313 yr by Dangercdv
February 12, 201313 yr Like danger said, same sub different size. Man don't even plan to put that much power on one of those subs. A 10 inch sub will be louder than an 8 if both are in their respectable boxes.How many are you looking at getting?
February 12, 201313 yr Author i plant to play 2 e8v3 or one sd 12which of these should be better or louder
February 12, 201313 yr Well, for your amp, neither.you might be able to get away with a sd-12 on that amp, but still that’s pushingit too far. You would really have to gain down and watch how far you turn upyour volume.I would recommend getting a weaker amp. As far as the subsgo I would go with a single 12 inch over the 8s. It has a bit more cone areaand it’s easier to work with.If you really want to work with that amp, I would save alittle bit more money and get an SA-12, it would handle your amp as long as youtune everything correctly and don’t overdo it. This would be your best option.
February 13, 201313 yr oh yeah, good point. Get a used SA-12, or 2 used SA-8 subwoofers, then just go crazy Whatever you decide to go with, make sure you tune everything correctly. Nothing worse then blowing brand new subwoofers because you didn't take the time to tune it right.
February 13, 201313 yr I can help you design a box for it, perfect specs. Just give me 24 hours (I have school)
February 13, 201313 yr Don't power one with that size amp bro. I have a sundown audio e 12 on a Polk audio amp that puts out 617 watts @ 2 ohms and that sub heats up quite a bit with proper gain.
February 13, 201313 yr Author hmm i understand but i play with a stock 40 ampere battery and a external shuriken 80 battery
February 13, 201313 yr What amp is it? I'd get a dual 2 12" e or sd series and run the amp at 4 ohms. It'll make your system more efficient and less strain on equipment.
February 13, 201313 yr hmm i understand but i play with a stock 40 ampere battery and a external shuriken 80 batteryThat has nothing to do with the sub heating up. Sure maybe voltage drops make the amp work harder and heat up the coil more but that has nothing to do with how hot the sub gets. The woofer has poor cooling simple as that.
February 13, 201313 yr hmm i understand but i play with a stock 40 ampere battery and a external shuriken 80 batteryThat has nothing to do with the sub heating up. Sure maybe voltage drops make the amp work harder and heat up the coil more but that has nothing to do with how hot the sub gets. The woofer has poor cooling simple as that.It actually has everything to do with it. His alt is small as hell which means its going to be hard to keep voltage high. When voltage drops clipping can occur which will heat up the sub up real fast. I think clipping can be like 3x the power (not to sure I think I read that somewhere). Maybe that's why your sub was getting hot.
February 13, 201313 yr autotek mm1-1500dRun it at 4 ohms to get the highest efficiency. From your amp at least. Get yourself a sub or subs that will have a final ohm load of either 1 or 4 ohms and wire them to 4 ohms .
February 13, 201313 yr hmm i understand but i play with a stock 40 ampere battery and a external shuriken 80 batteryThat has nothing to do with the sub heating up. Sure maybe voltage drops make the amp work harder and heat up the coil more but that has nothing to do with how hot the sub gets. The woofer has poor cooling simple as that.It actually has everything to do with it. His alt is small as hell which means its going to be hard to keep voltage high. When voltage drops clipping can occur which will heat up the sub up real fast. I think clipping can be like 3x the power (not to sure I think I read that somewhere). Maybe that's why your sub was getting hot.My voltage is a perfect 14.4 constant. The sub js in a sealed box built to specifications
February 13, 201313 yr Author Don't power one with that size amp bro. I have a sundown audio e 12 on a Polk audio amp that puts out 617 watts @ 2 ohms and that sub heats up quite a bit with proper gain.how long dit you played that the sub getting hot..
February 13, 201313 yr Don't power one with that size amp bro. I have a sundown audio e 12 on a Polk audio amp that puts out 617 watts @ 2 ohms and that sub heats up quite a bit with proper gain.how long dit you played that the sub getting hot..45 minute drives. If you don't drive that much i wouldnt be worried about it
February 14, 201313 yr Author Don't power one with that size amp bro. I have a sundown audio e 12 on a Polk audio amp that puts out 617 watts @ 2 ohms and that sub heats up quite a bit with proper gain.how long dit you played that the sub getting hot..45 minute drives. If you don't drive that much i wouldnt be worried about itim not driving that much long i drive around 10-25 minutes
