Posted March 3, 201313 yr I have a Rockford Fosgate T2500 amp. I want to get an Fi BL 18' woofer what options should I choose for the woofer since I have a RFT2500 amp?
March 6, 201313 yr Load that sucker up get every option but make sure you get dual 2 ohm if you want a 1ohm load on the amp
March 10, 201313 yr Dual 2 OHMP Chamfer: YesCooling: YesHiXmcoil: YesDailyUniversial: Yes incase you ever want to recone it to Dual 1 OHM
