Posted March 4, 201313 yr Hi I was in my friends ride yesterday and heard a problem ive never read about When he turns his radio on, there is a static noise very similar to one youmight hear from white static on a tv This noise starts before the music does and continues throughout music playBesides the annoying sound in the background, the music sounds fine Dude told me he just got a new radio cause he was hookingan amp up in the back and his headunit started smokingI could not figure that 1 out either,maybe he hooked the remote from the old radio2 the batt and ground at the same time? If you have seen my subs in the backseat thread, then u know my standards are not very highhttp://www.soundsolutionsaudio.com/forum/topic/58347-my-system-yep-subs-in-the-backseat-yep/but this guys system made me shake my head and made me nervousi was sitting on speaker wiresthere was wires hanging out the dash too I want 2 help him
March 4, 201313 yr 1. Clean it up haha. 2. Check all the grounds and powers make sure nothing is touching the RCA cables and make sure everything is secured down tight. 3. Check RCA's make sure they are not touching any other wires, and make sure they are not cut or showing bare wire anywhere. if that doesnt help if you are playing with your phone through a AUX jack and it is charging that will give the same static effect/motor noise.if all else fails try a new pair of RCA jacks.
