Looking to buy a saz 2500 and just seeing what you guys think i should do about electrical to power the amp. It'll be pushing a sp4 reconed by psi audio, they told me that it will be 2500 rms or better. ill be running the amp at .5 ohm. For electrical so far i have the big 3, a 350 amp alternator by bnr parts (junk by the way) looking for a 270 amp alt by mechman and a xs power d3400 under the hood with all 1/0 gauge. Just trying to get some help with what i should upgrade to run .5 ohms daily. looking to get dual toolmarker 1/0 for the power and ground for 2 runs of 1/0 wire. should i be looking at another battery? and what if i got just a smaller battery and put the 3400 in the back? Any help is greatly appreciated.
You are looking at 250 amps of draw so a good alternator and an extra battery should be sufficient.
dont run it at .5
dont run it at .5
Yes I would also advise against running it at .5 simply because it isn't covered under warranty if it shits out which is very likely if you push it too far.
