Posted March 12, 201313 yr As the topic suggest what's the max wire gauge that will fit in the zcons terminals ? Also do you have to run fuses from your battery while running the wire back from the battery ? Thanks in advance going to order all my wiring and fuses tonight.Also the ebay dealer backed out so I purchased another zcon w cb dust cap. So atleast I know I'll have nothing to worry about sub wise.
March 12, 201313 yr Author Battery from the negative I mean, as i know you have to from the pos just wasnt sure about from the negative.
March 12, 201313 yr I don't know the max wire size in the terminal, but you really don't need excessively large cable. Of course, people think bigger is better, so you see people running large gauge cable. If you have to have large cable, but some 10ga. No fuse on the ground and you don't even need to run it from the battery -. Just find a solid metal point on the car, remove the paint, and secure it with a bolt. Then caulk over the ground.
March 12, 201313 yr Author Thanks again, hopefully gonna start my build log once I get fully moved into the house. Then I'll be set.
