March 24, 201313 yr yep, here's another twist to that argument too.. There are many high efficient drivers that are rated for low rms and lower efficient drivers rated for high rms.
March 24, 201313 yr This is primarily due to the fact that the attributes needed to ensure retard-high thermal ratings kill efficiency... It is a double edged sword...
March 25, 201313 yr yep, here's another twist to that argument too.. There are many high efficient drivers that are rated for low rms and lower efficient drivers rated for high rms.Efficiency doesn't correlate to output capabilities either.
March 25, 201313 yr the loudest woofers are proven to have chrome all over them, and a few blue lights dont hurt either.
March 25, 201313 yr Popular Post Goddamn Jon, lol... And yes, higher efficiency doesn't indicate output capabilities either, good point Impious... There are plenty of 100db drivers that can't tolerate more than a few watts... So many people disregard modeling programs siting them as not real world. But these modeling programs are what will help you make the correlation between output capabilities and power requirements for said output. And it takes many parameters to derive this. But it doesn't require one parameter, and that is the RMS rating of the subwoofer... There is much more to be learned from modeling these drivers (and all drivers on earth model as predicted if you know what you are looking at) than here-say on an internet forum...
March 25, 201313 yr Maybe try port on the right side. Different port placement could maybe get you louder.
March 25, 201313 yr new box design buddy... seems to be the concensus ..... go with "more" port and different orientation as well.... not that it "can't" work but apparently isn't for you
March 25, 201313 yr Looks like that box has a raised Sundown Audio logo. The port does look a bit awkward. Edited March 25, 201313 yr by BrutalBasser
March 25, 201313 yr yep, here's another twist to that argument too.. There are many high efficient drivers that are rated for low rms and lower efficient drivers rated for high rms.Efficiency doesn't correlate to output capabilities either.Don't you mean sensitivity/SPL rating (1w/m or 2.83V/m).Efficiency does correlate to output, because efficiency=(Usefull energy/Total energy)*100% . (which in this case is acoustic energy divided by energy put in the driver times 100%)
March 25, 201313 yr Author Looks like that box has a raised Sundown Audio logo. The port does look a bit awkward. That it does. The guy who traded it had a Sundown sub in it. It's a Z port or whatever it's called. Not just single slot. It does a zig zag in the box. It looked small to me too. My old boxes port is practically the size of this box. Little sarcastic, but still. I'm not a box expert. I've built two boxes total, my last box however was a very nice box if I must say. Just was for a friend, not me. We built a box for his Sundown Z v.2. Edited March 25, 201313 yr by hatrix
March 25, 201313 yr yep, here's another twist to that argument too.. There are many high efficient drivers that are rated for low rms and lower efficient drivers rated for high rms.Efficiency doesn't correlate to output capabilities either.Don't you mean sensitivity/SPL rating (1w/m or 2.83V/m).Efficiency does correlate to output, because efficiency=(Usefull energy/Total energy)*100% . (which in this case is acoustic energy divided by energy put in the driver times 100%)I was referring to reference efficiency, which is the percentage of electrical input converted to acoustic output. Sensitivity is simply reference efficiency expressed in the decibel scale. And it doesn't mean anything as to which driver will ultimately have higher output capabilities.
March 26, 201313 yr Author What are the dimensions of the port. I mean the external height and width. That I don't know..... Yea I know, really wish I did. My friend is dumb and didn't ask for the exact specs of the entire box when he traded for it. It might very well not have enough port area. But I've been using it for 6+ months and it sounds perfectly fine, at least from the drivers seat Might have crazy port noise in the back...
