May 3, 201313 yr Author lol even with the miss spellings YEa, I looked at a few of those earlier... I have been looking at spings for a very long time ... thanks for the link ass.... lol http://lmgtfy.com/?q=H%26R+and+Eibach+coil+spings
May 3, 201313 yr Depends on how much money you want to spend. Eibach and H&R are both great brands. I dropped the Benz, you should drop the Camry
May 3, 201313 yr Author Depends on how much money you want to spend. Eibach and H&R are both great brands. I dropped the Benz, you should drop the Camry lol.... the H&R and Eibach are within $40 .... so its a moot point there... but stock is obviously WAAAAAAAAAAAAAY cheaper
May 3, 201313 yr Well it depends on if you are keeping the car long term or selling it in a year or two.
May 4, 201313 yr Stock wheels, tires, and the rest of the suspension and you're not looking for performance, so why even contemplate the lowering springs?
May 4, 201313 yr Author Stock wheels, tires, and the rest of the suspension and you're not looking for performance, so why even contemplate the lowering springs? Yea I know.... its been in my head already.... I mean it would look nicer lowered is all..... but I just need it to be fixed which is why I'm most likely going with stock suspension... Can I get some feedback on this set? It's basically a pre-assembled kit. Would come out just under $200 for this kit. http://www.rockauto.com/catalog/moreinfo.php?pk=4425198&cc=1434117 Edited May 4, 201313 yr by Shogen
May 4, 201313 yr Preassembled would be a much quicker and easier install. It would eliminate needing to compress the springs on and off.
May 4, 201313 yr search around theres Rockauto coupons floating around. Code 1376153311265608 = 5% Discount Edited May 4, 201313 yr by DanP
May 4, 201313 yr Author Yes, quickstruts are the way to go IMO. Just stay away from Monroe. yea the mechanics that work for them are a-holes too!
May 4, 201313 yr Author search around theres Rockauto coupons floating around. Code 1376153311265608 = 5% Discount Thanks man!!! Every little bit helps !!!
