Posted March 25, 201312 yr Recently purchased an Image Dynamics ID8v3 and built a vented enclosure tuned to 32Hz with 330w from an RE Audio DTS 1000.1. Love the SQ of the ID8, but now wanting more SPL and volume. I have a limited air space (0.6 ft^3 max) and limited mounting depth ( 5.25"). Was wondering if an SD-2 10" @ 2 ohms in a sealed enclosure would have more SPL than the ID8 in a ported 32Hz tuned box? Also, what would be the minimum air space for an SD-2 10" and recommended port tuning at 560 watts? Thanks
March 26, 201312 yr Was wondering if an SD-2 10" @ 2 ohms in a sealed enclosure would have more SPL than the ID8 in a ported 32Hz tuned box? No, you'll be down quite a bit of output over the main subwoofer passband. What vehicle are you installing in ?
March 26, 201312 yr Author 2000 Chevy S10 extended cab. Want to maintain the extended cab area and jump seat for my son; reason for the limited airspace and mounting depth. The box is mounted against the rear cab wall and the woofer fires forward.
