I have an arc audio 1200.1 amp I have not used it yet but wanted to see if anyone on this thread had any opinions on it. I also have bc2000D amplifier. I realize the wattage difference. I have been told that the arc will be very effecient. Should I expect the same out of the crescendo? Just exploring options. My build if for my daily driver.
You probably won't hear a difference between the two. If I had both I would most likely run the ARC.
I would run the arc amp.
