I have this amp hooked up to four. Infinity kappas 62.11 6 1/2 2ohm coaxial speakers . My speakers do 75watts rms. the amp claims 100 watt rms @ 2ohm per channel . How do I correctly set my front and rear gains, I should ask this is in a different way should I be using a multimeter or by hearing. What would be the correct way, I do have it on HPF vs full range. Also to any replies if multimeter is used what's the correct way, I understand the meter for the most part. Thank you
Using a DMM is not the best way to set the gain.  Neither is using an o-scope.  Nor the DD-1.
Simplest and best solution is to set it by ear.
Thanks
My amp is going into protection mode while I get it cranking, but some songs get really loud and it doesn't go into protection mode, gains are only half way up if that, Is This happening because of a bad ground ? My battery is in the trunk and I grounded my amp with my batteries ground on the bracket which is welded to the trunk body. I know that it's a terrible spot, if I bolted my amp ground on the same bracket as my battery ground Would that work?
Amp listed at the top. Yea at high volume some music can play a lot louder without it doing it. I will try that, didn't know if it was a good idea or not to go directly to the batt neg
