This is my first build so I only know what I have researched,  I will be buying a Fi BL 12 subwoofer to put in my Ford Ranger XLT.  I am not sure what amp to buy and please no used ones.
gotta be more specific....how much u want to spend, sq or spl, how much power
Post your coil configuration your BL is. (Dual,2 or 1) also what is your budget and what is you electrical system like? Extra upgraded battery? High output alt? Wire size and is big three done?
Are you planning on buying another one in the future? If not I would get a dual 2 ohm bl and run it at 1 ohm. But we can't recommend an amp with out knowing the budget. Depending on how much power you want to run, you might need to do some electrical upgrades. Big 3 is definitely a must though.
