I have a batt bank, 2 hc2400's and a hc1800
Bought a 200 amp power bastard alt that is a direct fit for my 02 taurus
It spiked to 16+ volts when i hit the gas lights got real bright then the voltage regulator
kicked in and it settled back to 14.5 v. Sent ot back they put in a new regulator
same problem. Bought a HO rebuild kit for my stock alt, same problem. Went to
a local mechanic and he said there is no way to solve the slow regulator issue
I'll buy a mechman if they can solve this issue. I also need a direct fit due to space restraints
Why is my HO alt having these issues.
Possibly a bad battery. Sounds like the most likely answer. Big 3 upgrades done? Do you have proper grounding and wire size?
Edited by BrutalBasser
Big three - yes
Doesn't do it with stock alt
My batts stay for days above 12.76v and 13 to 14.4v with car running
With stock
I would try testing each battery individually out of the car after resting for at least two hours. If one of them is going bad, it will eventually ruin all of the others in time. This will also cause charging spikes like you are having, and burnt out regulators.
Already tested individually. Is it possible to disconnect batts and run off
alt and see if it surges. I mean if I can do it on stock alt why not the HO alt
The H.O. puts out more current than your stock alternator. This creates more heat inside of your batteries, and if cells are going bad, you get these issues as described.
Lets say I go buy a car batt tomorrow the biggest I can get. That should stop
The voltage spikes. If that doesn't work any other ideas
What is your current front battery? Is it AGM?
Disconnect the 2400's and test the 1800 under a load. Do you currently have your HO alt in?
I changed it out tonight but the messed up part is I've swapped out my alt so many times
I can do it in fifteen mins I'll change it back to the HO tomorrow and try each batt seperately.
I originally started with the hc1800 and the ho alt got pissed put the stock back in and then added the hc 2400's to solve dimming issues. But the ho alt really makes the bass
hit, thats why I want it to work so bad. I,ve only recently decided to put the ho back in when
I read a batt bank is required with ho alt.
I also checked my batts when they were new and the autozone guy said they all
were bad didn't pass cca test. But I heard cca's are low on kenetiks and should
measure using ah
I am almost certain you have a bad battery. I have had experience with this same issue.
Just ordered a couple new hc2400's and bought a cranking batt also ordered
a motocraft voltage regulator and gonna swap out that crappy aftermarket
regulator then see how it goes I'll update after the alt install
I have heard bad things
and had a bad experience
with powerbastards 200-220amp alts
especially the universal fit ones
It's actually direct fit alt,not universal and I changed the regulator when I first got the
alt since I was getting voltage spikes and the one I ordered to replaced it was exactly the same brand and model that came with the HO alt but I didn't know
until I opened the alt up. I also bought a HO rebuild kit from a different site for my old burnt up stock alt and that even came with the exact brand regulator with the exact same voltage spike issue. So with the new batts and oem regulator I hope it will
solve my dilemma. This will be my last attempt with a HO alt or it'll be batt bank and stock alt.
I had the same problem with my alt from mechman it is a direct fit. My head lights would get bright as I gave gas plus air bag light would blink on and off until My headlights burnt out on freeway. So I stuck my stock one in and had no problem. Contacted mechman sent out alt on Friday by thurs of following week already shipped back said it was a faulty regulator installed back in and bought a cheap tempory batt from Walmart so far so good. Great service from mechman
mechman is great, love my mechman,
 funny story, over the weekend at a usaci meet, after my street beat run, ( music for 30 seconds score averaged )every one came up to me.. what kinda alt do you have man, where did you get it it on and on...
 see, every one else starts high at the beginning (good voltage and reserve ) but they quickly start falling in Db's   .... when i ran, i started at 149.0 db and ended at 150.2!  something you never seen in the lane. but  i never fall like most the guys do, and i dont even have very much battery reserve    mechman 6 phase technology !!
I love my Mechman too. I hardly ever have voltage issues and my amps love the power.
DC has had this technology for years..  but it's hard to convince those who've seen their performance in the past do business with them now.
That's a shame too. I inquired about an alternator from them, and I never got a single response out of five emails over a two month period.
I ordered mine around this time last year.  Got it powder coated, all specs understood via phone and ETA was right on the dot throughout the process.
At the time i ordered, it wasn't ready but now it may be.
There checkout system is setup to give you up to the minute progress information far more detailed than what'd you see on a tracking number for example with the progress of the alternator build.
