April 3, 201313 yr Author is that located behind the speedometer? cause that would be a huge undertakingi would bust a nut if i couldn't get it back together or one of the plastic pieces broke
April 3, 201313 yr Use a single pole double throw switch to run either two speakers under the hood or switch it to run the door speakers.
April 6, 201313 yr . You can purchase a variable on off volume knob so when you turn it down you can click it off and wont cause any spikes to damage your amp I actually use one for my center channel. Make sure it can handle the load you'll put on it. Remember old time knob radios when you turned the switch it clicked on then you turned up the volume.Same thing and when its off you convert back to 4 ohms.
April 6, 201313 yr They have them at parts express 8 ohm 100 watts. They dont click off but they'll go to zero which is the same thing
