April 5, 201312 yr I would personally go with a 300 amp, that is about the biggest I would use on 1/0 (which I assume is what you have). I highly doubt the Bc3500 will pull more than that, so it should suit it fine.
April 5, 201312 yr This is what I use. http://www.sonicelectronix.com/item_36278_Xscorpion-ANL1010P.html http://www.darvex.com/store/pc/Sound-Quest-ANL-Fuse-Holder-28p365.htm Edited April 5, 201312 yr by pmureika
April 5, 201312 yr I have a different brand but it's the same exact style. (Might be made in the same factory for all I know) It's not the fanciest but I am bangin on a budget over here and it does the job.
