Posted April 9, 201312 yr Soon I will be starting the rebuild in my SRT. I will be reconing the subs, adding some new mids and highs, new enclosure, new amp rack, battery bank, and possibly some exterior additions as well. I will try to get all the pictures that I can. Should be a good one this year.
April 10, 201312 yr Author Work begins Sunday on this project. This install will be clean as hell too. I went fancy pants and bought some awesome carpet for everything.
April 10, 201312 yr Author Before photos demanded!!!Will do, the subs are already pulled, but everything else is intact.
April 15, 201312 yr Tuned in! I love loud trunks. Hopefully I can be around your level sometime this year.
April 15, 201312 yr Author Tuned in! I love loud trunks. Hopefully I can be around your level sometime this year.The new setup should be crazy loud and low. Here is a video of this setup just playing around.
April 15, 201312 yr Author I want to see some pictures of that car I'll get some pictures of the entire car when I get the build done.
April 15, 201312 yr Author Any ideas on how to get the spray foam off the carpet without using gasoline?
April 18, 201312 yr Author The first enclosure I had in with the Mayhem's.Some friends after a loud afternoonA couple pictures of the car, I will put more up for Sean soon.
April 18, 201312 yr That's crazy how you got all that in there lol aren't the trunks really small? Can't wait to see the btl reconed setup!
April 18, 201312 yr Author That's crazy how you got all that in there lol aren't the trunks really small? Can't wait to see the btl reconed setup!Yes the trunks are tight on space. I had to modify the rear deck supports because I had to cut metal out to fit the enclosure in from the backseat that also had to come out. The rebuild is going to be as clean as I can get it. I don't want to give too much away because sometimes things don't go as planned.
April 19, 201312 yr Lookin good so far, tuned in for some results. I myself am gettin ready to try my hand with some 12's again with more power.
