Soon I will be starting the rebuild in my SRT. I will be reconing the subs, adding some new mids and highs, new enclosure, new amp rack, battery bank, and possibly some exterior additions as well. I will try to get all the pictures that I can. Should be a good one this year.
  • Replies 61
  • Views 5.9k
Tuned in!
Work begins Sunday on this project. This install will be clean as hell too. I went fancy pants and bought some awesome carpet for everything.
sweeeett
Tuned in too see!
Before photos demanded!!!
Will do, the subs are already pulled, but everything else is intact.
Here are some before pictures I got today.
IMG_0605_zpsecc280cb.jpgIMG_0606_zps628c2deb.jpgIMG_0608_zps437b85a0.jpgIMG_0609_zps509afba5.jpgIMG_0610_zps041970b8.jpgIMG_0612_zps4784c6c7.jpgIMG_0619_zps1e44179d.jpgIMG_0604_zpsef6dd621.jpg
IMG_0626_zps73ebeef1.jpgIMG_0628_zpsf90db658.jpgIMG_0634_zps36181946.jpgIMG_0636_zps6e0a7c48.jpgIMG_0638_zps19ae25de.jpgIMG_0623_zps74f789d5.jpg
Stripped subs in their new home.
562467_10200863550969531_501302569_n_zps
Tuned in! I love loud trunks. Hopefully I can be around your level sometime this year.
The new setup should be crazy loud and low. Here is a video of this setup just playing around.
I'll get some pictures of the entire car when I get the build done. :)
Any ideas on how to get the spray foam off the carpet without using gasoline?
The first enclosure I had in with the Mayhem's.
Photo116_zps1eff82e4.jpgSome friends after a loud afternoon
Photo197_zps21b208cb.jpgA couple pictures of the car, I will put more up for Sean soon. :)
That's crazy how you got all that in there lol aren't the trunks really small? Can't wait to see the btl reconed setup!
Yes the trunks are tight on space. I had to modify the rear deck supports because I had to cut metal out to fit the enclosure in from the backseat that also had to come out. The rebuild is going to be as clean as I can get it. I don't want to give too much away because sometimes things don't go as planned. brick.gif
That's why you got it all to fit. Ill be waitin to see how it all turns out!
Carpeted the enclosure tonight.
Badass man!!! Lets see it in the car with subs in it now ;)
Lookin good so far, tuned in for some results.  I myself am gettin ready to try my hand with some 12's again with more power.
