Posted April 19, 201312 yr I just had two of the DD1508 subs installed in my trunk and am absolutely amazed at what they are putting out. These frigging subs pound and sound like (2) 12's. has anyone else had the pleasure of running these same subs and if so any comments on the way they performed?
April 22, 201312 yr Nah dd makes great sq oriented drivers thoughAre you high? SQ, rofl. In general you could have done way better in the same space.
April 22, 201312 yr I heard a 1508 once and it sounded good. Mostly likely the box thoughAh, subjectivity. Amusing what the human body perceives without a comparison. SQ is FAR from the design criteria of the DD drivers.
April 22, 201312 yr I heard a 1508 once and it sounded good. Mostly likely the box thoughAh, subjectivity. Amusing what the human body perceives without a comparison. SQ is FAR from the design criteria of the DD drivers. what do you considered sound quality then?
April 22, 201312 yr Non-peaky would be a start. Not the topic of this thread, but the DD were designed with output in mind not a linear response so they may be appropriate for the OP.
