April 13, 200620 yr Powershifting is when you shift a manual transmission w/o taking your foot outa the fuel. Granny shifting is shifting a tranny the normal slow wayNever heard of speed shiftingGranny gear = uber low gearing.<{POST_SNAPBACK}>Holy crap you got double clutching right If anyone needs to know why it would be used in performance driving, watch the chase scene in Bullitt, McQueen 2x shifts a lot near the end.Speed shifting is shifting without using the clutch, often times you'll still have the petal mashed so it's very similar to power shifting.
April 13, 200620 yr Frenched = ressesed, lights, plates, etc...speed shifting is hard a phuck in all but 4th and 5th gears...dont know how nascar guys do it.doubleclutching is used to keep traction steady in heavy breaking when entering a corner in syncronised rannies while performance driving. a sudden engine brake could cause a skid, hello outside wall, or oversteer, hello world going round in circles.though you dont have to double clutch, you can just rev match with the clutch in.power shifting helps tons with turbo cars... especialyl thoes w/o BOV's oh yeah, BOV = tweeter = blow off valve
April 14, 200620 yr When you take the CDL test, you are supposed to double clutch, in reality, no one does. My understanding of double clutching is (never had to use it since I've never takin the CDL test, don't plan on it either, but I can still drive a semi...) Use the clutch to put the transmission in neutral, match the revs needed to downshift and use the clutch again to put into gear again. Used on unsychronized transmissions, you don't even need to do it if your know what your doing. in illinois, you have to double clutch to pass the CDL test, and they watch for it! and you have to double clutch whether upshifting or downshifting. you also have to downshift twice before each stop.double clutching in older trucks is real work, some newer ones, not too bad. but it's a crap ton easier to "slipshift" (matching revs and not using the clutch) then it is to DC.waterbox= spot to get the tires wet before a burnout at a dragstriptree= the starting lightsnomansland= the end of the dragstrip where it's all brakes and prayers. and if your prayers aren't answered...sandbox= where you go after nomanslandtrailered= where you go after losing at the strippuckertime= that moment before you know something bad or on the edge is about to happenwhiteknuckle= gripping the steering wheel extremely tight, usually associated with puckertimeholeshot= leaving the starting line first, usually by quite a bithole= starting linewheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
April 14, 200620 yr Hot boxing= smoking the reefer in the car, usually filled with smokeReally thought hotboxing was when you bogart and turn it all into cherry, could happen in a car I suppose though.
April 16, 200620 yr Hot box is all things smoked andin order to actually hot box the rooms has to be filled with smoke like, cant see through the car filled
April 17, 200620 yr I surely didn't type this, but here is a list of car acronyms which fit the jargon category:5MT - Five peed manual transmission6MT - Six speed manual transmissionABS - Antilock Braking SystemA/C - Air ConditioningAFRs - Air Fuel RatiosALS - Anti-lag SystemASR - Anti-Slip Regulation (traction control)AT - Automatic TransmissionAVCS - Active Valve Control System (Subaru)AWD - All Wheel DriveBBK - Big Brake KitBHP - Brake HorespowerBOV - Blow-Off ValveBPV - Bypass ValveCAI - Cold Air IntakeCEL - Check Engine LightCVTC - Continous Variable Timing Control (Nissan & Infiniti)DCCD - Driver Controlled Center DifferentialDiff - DifferentialDIN - Deutsche Industrial Norm, radio dimension standardDOHC - Daul OverHead CamsDPFI - Dual Port Fuel InjectionDSM - Diamond Star MotorsDP - DownpipeEBC - Electronic Boost ControllerEBD - Electronic Brake-force DistributionECU - Engine Control UnitEFI - Electronic Fuel InjectionEGT - Exhaust Gas TemperatureEM - Engine ManagementETC - Electronic Throttle ControlF/I - Forced InductionFI - Fuel InjectionFMIC - Front Mount IntercoolerFPR - Fuel Pressure RegulatorFWD - Front Wheel DriveH4 - Horizontally opposed 4 cylinder engineHID - High Intensity DischargeHLSD - Helical Limited-Slip DifferentialHP - HorsepowerHVAC - Heating Ventilation Air ConditionI4 - Inline 4 cyclinderIAM - Ignition Advance Multiplier (part of the ECU's engine control scheme)ID - Inner diameterJDM - Japanese Domestic MarketKPH - Kilometers per HourLHD - Left Hand DriveLSD - Limited slip differentialMAF - Mass Air-Flow SensorMAP - Manifold Absolute Pressure SensorMBC - Manual Boost ControllerMIVEC - Mitsubishi Innovative Valve Timing and Lift ControlMPFI - Multi-Port Fuel InjectionMPH - Miles per HourMT - Manual TransmissionNA - Normally AspiratedO2 - OxygenOBD-II - On Board Diagnostics IIOEM - Original Equipment ManufacturerOHV - OverHead ValvesPCV - Positive Crankcase VentilationPSI - Pounds per Square InchRHD - Right Hand DriveRRFPR - Rising Rate Fuel Pressure RegulatorRPM - Revolution per MinuteRWD - Rear Wheel DriveSAFC - Super Air Fuel ControllerS/C - SuperchargerSES - Service Engine SoonSFI - Sequential Fuel InjectionSMIC - Side Mount IntercoolerSOHC - Single OverHead CamSTS - Short-throw ShifterTB - Throttle BodyTQ - TorqueTBE - Turbo Back ExhaustTCU - Traction Control Unit (the computer that controls the DCCD's action)TMIC - Top Mount IntercoolerTPS - Throttle position sensorTDC - Top Dead CenterTSB - Technical Service BulletinTT - Turbo timer or Twin turboUP - UppipeUSDM - US Domestic MarketVIN - Vehicle Identification NumberVLSD - Viscocious Limited-slip DifferentialVTEC - Variable Valve Timing and Lift Electronic Control (Honda & Acura)i-VTEC - Variable Valve Timing and Lift Electronic Control with Intelligence (Honda & Acura)VVT-i - Variable Valve Timing with Intelligence (Toyota & Lexus)VVTL-i - Variable Valve Timing and Lift with Intelligence (Toyota & Lexus)WAI - Warm Air Intake (short-ram)WHP - Wheel HorsepowerWOT - Wide Open Throttle
April 17, 200620 yr didnt even see CAI, FF, FR, MR, RR...Cold Air IntakeFront Engine Frton Wheel DriverFront- RWDMid RWDRear RWD I/E/H = intake, exaust, and headers.
April 22, 200620 yr loud pedal= throttleone of my favorites!!twisty thing=throttle for a cycle..wrister= see above...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
April 24, 200620 yr TSC- Tractom ControllSpyder Gears- Outer roatting gears in a non locking rear endFive-O- Police, crown vic's in particular, and from what i was told was the crown vic's used to sport the mustang 5.0l engine...but that could be BSFart Can= Ricer exaustim bored
April 30, 200620 yr Five-O- Police, crown vic's in particular, and from what i was told was the crown vic's used to sport the mustang 5.0l engine...but that could be BS<{POST_SNAPBACK}>Crown vics all had a 302 in them, some contained the HO (high output) package, which was standard on all mustangs. Contained a diffent Cam, bigger injectors, higher proformence headers, different intake, and some other nick nacks.BUT PI (Police interceptors) often contained a 5.8L 351w engine, a bigger badder motor than the mustang.The 302 is inMustangsVicsGrand MarquisLicoln Town cars Used up to 92' I believe.They came either EFI or CFI, lots have undergone a full carb conversion.
