Posted May 18, 201313 yr I have a 99 durango with the overhead console that has the sunglasses holder and it rattles like crazy on the high notes. I was wondering if any of you guys have any suggestions on how to tackle this problem. Thanks
May 18, 201313 yr Talk to Don at sounddeadenershowdown.com he really knows his shit and would be able to tell you what is the best approach and what you should use. He will make sure you do not buy more that you actually need.
May 18, 201313 yr Well you wanna isolate the pieces of plastic from each other. Almost positive using ccf in.between the plastics will create a barrier so the pieces won't vibrate against each other...
May 18, 201313 yr Author I don't think there is enough room to put anything bigger than like some paper between the plastic.
May 18, 201313 yr Then get some really thin foam. Can be open cell, closed cell, rubber, doesn't matter. Perhaps some butyl rope would fit. Anything soft that you can fit in between is golden.
May 24, 201313 yr My rear deck had a bad rattle, the solution was a folded up sock wedged in between two pieces of metal. I have a TON of money invested in deadening but that damn sock worked perfectly in that spot. Isolate the noise by muting your front stage and shove something in between.
May 24, 201313 yr To go off another suggestion, window insulation foam (not even 1/4 inch thick) worked wonders for me in many areas. Might want to try that too. Works well and cheap.J
June 15, 201313 yr Any thick or small foam works wonders! I used refrigerator filters before found laying around stuff does wonders! Edited June 15, 201313 yr by Dictator
