May 20, 201312 yr Author ok the box got alot of air flow..an the person im trying to be louder than has 4 cvrs 2 ohms on two lanzar 2000 watt amps. my brother has the same subs on two 2200d audioque amps...
May 20, 201312 yr Build a good box with your equipment and you might be able to be louder. 2 totally different systems with you and your friend.
May 20, 201312 yr I'm going to try and make this as simple as possible. If you are trying to compete, you will want a completely different box tuned much higher, closer to 50hz for competitions (assuming you are doing burps). (Which won't give you the loud lows because frankly competitors don't use low frequency burps to compete because they aren't as loud). As far as speaker wire from the amp to the sub, nothing larger than 12 ga. is necessary, and will not yield any discernible improvement. As far as an improvement in the amplifier department, what is your budget? Lastly a properly built box is the single greatest improvement you can make in any system.
May 20, 201312 yr I'm going to try and make this as simple as possible. If you are trying to compete, you will want a completely different box tuned much higher, closer to 50hz for competitions (assuming you are doing burps). (Which won't give you the loud lows because frankly competitors don't use low frequency burps to compete because they aren't as loud). As far as speaker wire from the amp to the sub, nothing larger than 12 ga. is necessary, and will not yield any discernible improvement. As far as an improvement in the amplifier department, what is your budget? Lastly a properly built box is the single greatest improvement you can make in any system.^^Listen to this OP. As stated before, you need to change your box before blowing money on amps....will make a much bigger difference than just replacing amps.
May 20, 201312 yr Ok a solid box or seal or More seriously neither. Ported is what you need.That was a good one.
May 20, 201312 yr Ok thats what im.going to go with mdf boardBut you need to make sure its the right size and is ported to the proper frequency. The right box is the most important part of the build!
