Yea i haven't made a post in a while.
but came across this today.
Well let me say this I went to the audio shop to grab a couple ft of 1//0 and they want 5.60$ per foot.
I know its cheaper online, but weldingsupply.com has thier black 1/0 on sale for 2.15 or 1.99 if you buy over 50ft.
cant beat the price
https://weldingsupply.com/cgi-bin/einstein.pl?Next::1:UNDEF:OR:terms::PA#A2
  • Replies 53
  • Views 5.4k
  • http://www.electronbeam.com/
  • correct... and ALWAYS mention the facebook deal even if you didn't see one... they always have some kind of special going and they honor it when you mention it.... look up their facebook... I don't ha
  • bhsdriller
    bhsdriller
    you need 2/0 welding wire to equal 1/0 car audio wire that's why the 1/0 is cheap, it's smaller   iirc
cant beat the price
guess i need to get out more
no, I'm just helpful.... :-)
Welding wire ftw!
Any of you attempt using anything bigger than 1/0 with any luck? I'm thinking about upgrading to at least 2/0 and calling it a day.
cant beat the price
This stuff as good as the wire from welding supply?
only difference I have noticed is the jackets... doesn't seem as "sturdy/durable" ...not that it isn't durable but the weldingsupply wire jacket is beastly and makes it harder to deal with... even at the same gauge
cant beat the price
cant beat the price
Only way to order is to call? I cant see any order forms or anything.
jacket slides..  that is all.
 its perfectly durable
only way is to call correct.
correct... and ALWAYS mention the facebook deal even if you didn't see one... they always have some kind of special going and they honor it when you mention it.... look up their facebook... I don't has it anymore but it's there
cant beat the price
beat me to it
We reserve the right to end this sale at any time.
All good cable, just odd lengths and left over from longer lengths. You must take the entire length listed for the discounted price:
4/0 / 108 mm sq.(EBT 214-PXL) $ 3.05 per foot: Inventory 75’, 92’, 200’ ,250’ 250’ …..
3/0 / 85 mm sq. (EBT 168-PXL) $ 2.35 per foot: Inventory 24’, 40’, 54’, 58’, 59’,73’, 118’, 150’, 177’…..
2/0 /68 mm sq. (EBT 134-PXL) $ 1.90 per foot: Inventory 40’, 65’, 76’, 96’, 97’,98’, 175’, 245’, 282’……
1/0 / 54 mm sq. (EBT 107-PXL) $ 1.50 per foot: Inventory 25’(x 30 pcs),
44’, 48’, 50’, 54’, 58’(x 2 pcs), 63’ (x 3 pcs), 65’, 67’, 70’, 85’,
90’ (x 2 pcs), 95’, 245’…….
2 g / 35 mm sq. (EBT 69-PXL) $ 1.00 per foot: Inventory 40’, 98’.....
4 g / 23 mm sq.(EBT 46-PXL) $ 0.67 per foot: Inventory 32’ (x 2 pcs.), 129’, 153’, 258’, 290’.....
6g / 16 mm sq. (EBT31-PXL) $ 0.45 per foot: Inventory 35’, 161’, 284’.....
CALL CUSTOMER SERVICE AT 815-935-2211 AND TELL THEM YOU WANT THE REMNANT SALE PRICE!
iirc
Are you joking?  This is one of the most idiotic things posted in some time.
AWG is AWG unless the manufacturer is lying.  Welding cable will always meet AWG spec, car audio may not...
iirc
that's why I said iirc.....obviously I didn't lol
carry on then
That myth was formed because the diameter of the conductor for welding cable is smaller than most car audio wire because it's less stranded.  That's the only reason.
That myth was formed because 90% of people are too ignorant or lazy to properly inform themselves about products they are interested in. That's the only reason.
Just placed an order for 54 Feet of 1/0 from the Remnant sale..Thanks for the Link Shogen
Physical construction may be different, that is it.  The cross-sectional area of copper will always be the same unless the manufacturer is lying, which is almost never the case with welding cable, especially cable that has been rated by a reputable US third party.  Swap-meet garbage "car audio" power cable is where you run into erroneous AWG identification ...
You saw it (mistake) on this site last year with a cable comparison.  O.D. of the conductor portion was measured.  This tells you absolutely NOTHING when dealing with straded wire.  NOTHING.
The only way to make a meaningfull comparison is to measure the AWG of the individual strands and then count every single one.  If you don't do that, don't even try and compare cable.
all arguments aside thanks OP for advertising something that could be of use to a lot of us
thats the kinda stuff we need around here
You're welcome.... wish I had money, I'd get 2/0 and never worry about wire again. Lol
good wire but the case does slip, i found that using a good heat shrink at the ends helps it from sliding.. and i do mean good heat shrink not that skyjacker shit.
 i have been using this wire for years and years.... i was a  prick and kept it to my self.. i did share with steve mead .. but thats all..... its out of the bag now!! :D
The Royal Excelene I just bought is stamped 50mm2 on the jacket, which is technically smaller than 0/1ga by 3.5mm2 assuming it's an accurate number and they didn't just round for simplicity sake.  But worst case 3.5mm2 isn't enough to make a difference in any situation but those maxing out the capabilities of the wire, at which point it would be wise to step up a gauge anyways.
