Posted May 25, 201313 yr Hello everyone, I was using the search button, but I didn't come up with a solid answer. I'm hoping someone here can help me out. I'm looking for the recommend box size for 1 orphan sealed. I've read from other post that said the orphan are about the same as the SA-8 and likes the sealed box size of .17^3ft. I've also read a post from mike, that It needed .2 to .5^3ft, but I'm not sure if it was the recommended for seal or port. I actually wanted to try out they type of boxes and see which one sounds better to me. I do want to to try to make a passive radiator box, which I believe these subs were intended for. Here is the info from another post on this forum. T/S Parameters for the Orphan 8 Single 6 Ohm:Qts - 0.405Qes - 0.442Qms - 4.778Fs - 34.289 HzRe - 5.25 OhmLs - 12.16mHLp - 4.053 mHRp - 25.46 OhmVas - 5.031 LMms - 214.1 gCms - 100.6 m/NBl - 23.39 T*mSensitivity - 78.44 dB17mm Xmax
May 25, 201313 yr Per their site they recommend .5 sealed. I haven't modeled it so I'm not sure what the Q is at that volume.
May 25, 201313 yr Author yea, I just saw that too. Its not the same sub. Is there a way to actually calculate a subs recommended box size from the tech specs? I tried to use a slotted box calculator, but I am still trying to figure everything out and i think it needed a cubic ft size.
May 25, 201313 yr Author Thanks for the help by the way. I've been trying to get my head around everything the last couple of days and its a lot to read through.
May 25, 201313 yr Yea I calculated it but I believe that the VAS has to be wrong seems a little lowGoing by the parameters you need .08 cubic feet for a q of .7
May 25, 201313 yr Author Since I don't really understand the concept of Q. It looks like ppl want it between .5 and .7 to get a better lower response in a sealed box? It is impossible for a .08 cubic ft space to fit this sub. So, I should probably build the smallest box possible? So im really looking at a box of .17 cu ft after sub displacement? i think thats the smallest I've read about. The sub were supposedly make to work with a PR box, maybe thats why the specs are different....? Edited May 25, 201313 yr by rtenuso
May 25, 201313 yr normally people prefer a Q of around .707. It gives the flattest responce with the lowest rolloff point. However some like a slightly higher Q around .8-.85 that offers a slightly warmer feel with a little increase in DB. I dont have the formulas with me to calculate But I,m 99.999999 percent that the VAS is wrong. Vas is directly related to enclosure volume.
