Posted May 31, 201312 yr i just turned my dvc 4ohm 15" obsidians down to 1 ohm would i have to change my amp settings. and does the frequency have anything to do with hitting a low note.cause i have the gain n half way turnt up. along with the frequency
May 31, 201312 yr Author no you didnt. there is no way you can wire a single D4 sub to 1 ohm.i have two of them
May 31, 201312 yr Author You have two d4's wired down to one ohm?yeah i have two d4's wired down to one ohm
May 31, 201312 yr ah you didnt say that . use your ears nose and eyes. to set your gains and hz, is it a port or sealed box?
May 31, 201312 yr Author ah you didnt say that . use your ears nose and eyes. to set your gains and hz, is it a port or sealed box?yeah its a ported box.
