Posted June 5, 201312 yr ok so my first issue is that i have found a usa company that builts box, for these trucks behind the seat, im going with 8s on this build.... so the options are 3 8s sealed or 2 8s ported im leaning to sealed as he listens to country ,. the issue i am having is finding out how much space is left between the back of the seat and the box.. so i can make sure the subs wont hit... im looking at the sundown SD 8s or the sundown E8v-2 if there is not much space left./ has anyone done an install on a crewcab 2008-2013?
June 5, 201312 yr You can fit two 10's ported. The sa 8 will not fit its too deep (90% sure). You can fit a rectangular box back there all you have to do is remove the vents on the back wall and cover them with deadener or aluminum duct tape.
June 5, 201312 yr The last one I did was with two IA i87 10's ported and it sounded pretty damn good.
June 5, 201312 yr Author yeah the Sa 8 is too deep .. thats why i was looking at the Sd8 and the E8v2 the depth i can find on the boxes im looking to use is 5.25 and thats based on a 6 inch diameter motor i was looking at the Dcon 10's but they are too deep... i really do not want to build my own box. i would rather just order a made to order one.
