June 18, 201313 yr NAP...what the demintions on the portsYou can't just change the port, or your tuning/volume won't be right.
June 18, 201313 yr Author i think i can still use the boxes but make the ports bigger but with 6cuft it will bring my tuning up with a bigger port right
June 18, 201313 yr i think i can still use the boxes but make the ports bigger but with 6cuft it will bring my tuning up with a bigger port rightIf you make the ports as big as they should be it is going to take up a lot of volume inside of the enclosure, and most likely will not yield very good results. Post the dimensions of the enclosure and I can tell you for sure.
June 18, 201313 yr Your ports are to close to the hatch. That doesn't help let the airflow very well!
June 18, 201313 yr Author i was just messing with torres and if i give myself about double the port are..from .45 to .90 or so..it will lower the cuft from 6.01 to 5.61..and bring my tuning from 32 to 37
June 18, 201313 yr 80% Enclosure, 20% Equipment. You REALLY need to just start all over with the box. I have 130cuin of port for ONE 18".
June 18, 201313 yr i was just messing with torres and if i give myself about double the port are..from .45 to .90 or so..it will lower the cuft from 6.01 to 5.61..and bring my tuning from 32 to 37Post a screenshot.
June 18, 201313 yr That's a bit better, but not ideal. It's super easy and cheap to try, so I'd say to try it out and go from there.
July 1, 201313 yr Author Going from .52 to about 1.00 ft3 of port area. It is bring my tuning from 31 to 37 htz. Length is going from 15 to 18 inches total. Should let the subs breath a lil more. Im gonna try this before I rebuild the whole thing. Edited July 1, 201313 yr by disturbeddrummer254
July 5, 201313 yr ^^^cant bring myself to understand how to build port like that. But that's just me.
July 15, 201313 yr Author Well put it all back together and it sounds horrible. Im gonna have to tear it apart again n build a whole new box.
