June 26, 201312 yr Author Ok i will though we are discussing on it so did you mean further search the forum with other keywords or did i miss something?
June 26, 201312 yr The thing with a active setup all depends on you. A passive setup can and will sound very good to if setup right also.
June 26, 201312 yr Author Yea i gather as much i just figure since i want the 80 prs head unit and it has the capability why not as well as it sounds like a good plan for it to be customizable if all else fails and i suck at it ill just by a component set with a passive crossover
June 26, 201312 yr Ok i will though we are discussing on it so did you mean further search the forum with other keywords or did i miss something?If this is the only thread you've read and you no longer feel like searching, then I'd recommend you just run passive. Going to need a lot of motivation to finalize everything and if you are running out already the choice is made by you for you.
June 26, 201312 yr Author No im not running out im researching and googling constantly between calls at work this is very interesting i just am still trying to ascertain the basics
