Posted July 1, 201313 yr how many sheets of mdf would i need for a 4.25 to 4.5 cu ft box for two 12's and 2 cu ft per chamber and a 30hz tune going to build a box tomorrow so please let me know asap
July 1, 201313 yr I was able to get 5.3 cubes for my 2 12s but if I screwed up I would need another sheet. Get 2 so you don't have to waste gas if you need another one. The wood won't go bad if you keep it in a dry area
July 1, 201313 yr Author so the longest is 38x16 and i need 3 of that length so i can use 1 whole one and a few others
July 1, 201313 yr Author would there be anything wrong for have each chamber have there own port or should i have both subs use one port and where can i get terminal cups. and what is a good way to seal the cups
July 1, 201313 yr Author i will post all the specs for each pieceBox Bottom plate: 38 x 16Box Top Plate: 38 x 16Box left Plate : 15.25 x 14.5 x 15.25 x 14.5Box Right plate: 14.5 x 14.5 x 14.5 x 14.5Box Front Plate: 33.25 x 14.5Box Back Plate: 38 x 14.5Port L1: 12.5 x 14.5 x 12.5 x 14.5Port L2: 1 x 14.5this is all from re audio box calulatorbox dimensions are38x16x16x16 the local lowes only has this size3/4 x 48 x 96 Edited July 1, 201313 yr by grumby13
July 1, 201313 yr I would just get 2 to be on the safe side.Keep them same chamber it'll give the subs more space.You don't need terminal cups. Drill a hole and have the wire go through and seal it with caulk.
July 1, 201313 yr google would there be anything wrong for have each chamber have there own port or should i have both subs use one port and where can i get terminal cups. and what is a good way to seal the cups
July 1, 201313 yr http://www.delphiforfun.org/Programs/CutList.htmShould give you a general idea of what you need. If you only need a little more than one full sheet you can pick up 2'x4' mdf sheets at home depot for like 10 bucks.
July 1, 201312 yr damn 4 cubes in a camry? i want to see this. im sure it will fit no problem but my 3 cubes with my ported box is big and wide. it was a pain carrying it downstairs to my car. luckily it was easy to put in the trunk. like stated before you dont need to go all fancy. you can drill a hole for the wires and then silicon it up. i got my box design from another source.
July 2, 201312 yr Author just built the box i will add some pictures to this so you guys can see. it came out to 3.853cu ft. i have to see how to add picture to this page/forum. i went with a hole in the back i think i will add a rubber grommet that will not let or let a very little air through Edited July 2, 201312 yr by grumby13
July 9, 201312 yr Author so i measured the box after it was built and it came out to be larger then 3.853 cu ft. it came out to 4.3 something cubic ft internal volume
