Posted July 4, 201312 yr This is what I have currently a sundown sax 1200d on a treo 15 ssi in a 3 ft cu box ported to 35 hz facing rear and I am thinking going 2 gcon 10s firing forward sealed off from trunk it's a little smaller cone area but would be lighter on suspension car is a 99 camry trunk is 32 deep 19 tall 38 wide just want to get most bang for buck do u think I will lose any output or will I gain
July 4, 201312 yr Author No not going sealed that was my available space in trunk goal is sound good with good output not competing no spl
July 4, 201312 yr Not too familiar with the ssi Treo line but I believe a 15 has more cone area than 2 10's
July 5, 201312 yr Author I looked up the treo ssi specifications it has 750 rms xmax 27mm and 3 inch coil
July 5, 201312 yr Hard to tell if its going to sound louder or better quality.What are you trying to accomplish? overall sq? lows? You would probably have a safer bet if you saved up a few more dollars and bought dual icons, you would probably notice a bigger difference.
