Posted July 15, 201313 yr Just finished this up for a friend nothin fancy it's a budget build and it slams, it's one zv3 12" in a ported box with a crescendo 2k 0ga all the way to the battery has two batterys but the one already took a shoot, has a digital volt gauge and it drops below 10 on a low note but anyway here's some pics it gets the job done With the seats out Is fully sealed, no leaks that i could see so far Edited July 15, 201313 yr by 388chevy
July 18, 201313 yr I wish I had the balls to cut through my cab, sure would free up some space back there. I hope you get a hold down strap on the battery before it arcs out on the amp and some grommets/strain reliefs on the wires passing through the cab.The power cable is fused I hope.
July 18, 201313 yr Not bad at all. My boy use to have a S10 a few years newer with 2 18" Strokers. Got crazy loud.
July 18, 201313 yr He actually broke the S.C. state record at a comp. in Myrtle Beach. I don't remember what class or dB's. This was like 12 years ago.
July 18, 201313 yr Author I wish I had the balls to cut through my cab, sure would free up some space back there. I hope you get a hold down strap on the battery before it arcs out on the amp and some grommets/strain reliefs on the wires passing through the cab.The power cable is fused I hope. Straps yes working on getting some, power cable is deff fused i mean who doesn't fuse a power cable with that big o cable?
July 19, 201313 yr I wish I had the balls to cut through my cab, sure would free up some space back there. I hope you get a hold down strap on the battery before it arcs out on the amp and some grommets/strain reliefs on the wires passing through the cab.The power cable is fused I hope. Straps yes working on getting some, power cable is deff fused i mean who doesn't fuse a power cable with that big o cable? Fused, good. No grommets/strain reliefs, bad.Only a matter of time before you're doing it again. Who doesn't fuse their power cable? More than you think.Watch the news for car fires, there you go.If it's worth doing, it's worth doing right the first time. For future referrence, 0gs, isn't big that big of cable.Suit yourself, it's not my truck.
July 19, 201313 yr Author I wish I had the balls to cut through my cab, sure would free up some space back there. I hope you get a hold down strap on the battery before it arcs out on the amp and some grommets/strain reliefs on the wires passing through the cab.The power cable is fused I hope. Straps yes working on getting some, power cable is deff fused i mean who doesn't fuse a power cable with that big o cable? Fused, good. No grommets/strain reliefs, bad.Only a matter of time before you're doing it again. Who doesn't fuse their power cable? More than you think.Watch the news for car fires, there you go.If it's worth doing, it's worth doing right the first time. For future referrence, 0gs, isn't big that big of cable.Suit yourself, it's not my truck.Always people hatin' and theres not much strain on the wires the holes were drilled with some room to spare
July 19, 201313 yr You neg. rep. me for pointing out a couple of things that could ruin your equipment or start a fire in the truck.That's nice.I'm gone.
July 19, 201313 yr Author You neg. rep. me for pointing out a couple of things that could ruin your equipment or start a fire in the truck.That's nice.I'm gone.Thanks Love those S-10's!Post a video up to see what she can do! Here's a vid i'd turn the volume down sounds like poopy
