Posted July 15, 201313 yr So I've had the big 3 in my car for about a month and a half now everything was fine until this morning I opened my hood and one fitting was melted. It has 1 0gauge going to the battery and 2 4gauge going to starter and the other going to my fuse box. My car turns off as soon as I turn my AC on my car turns off. Also the 4 gauge going to the fuses had the insulation gone completely melted
July 15, 201313 yr Author alright i think i got the hang of it this is a pic of the wire with tape on it after it melted i went down to a local shop ti buy a replacement fitting, they gave me this cheapass stinger that didnt fit my wires http://s1288.photobucket.com/user/josedragonhernandez/media/IMG_20130715_154214_zpsc5d9c3e9.jpg.html?sort=3&o=4 Edited July 15, 201313 yr by dragon123443
July 15, 201313 yr Author my bad lol heres link to last posthttp://s1288.photobucket.com/user/josedragonhernandez/media/IMG_20130715_154545_zps8527c7a2.jpg.html?sort=3&o=0
July 15, 201313 yr Author pic of burnt onehttp://s1288.photobucket.com/user/josedragonhernandez/media/IMG_20130715_154526_zpsee12eaf3.jpg.html?sort=3&o=1
July 15, 201313 yr Author burnt one http://s1288.photobucket.com/user/josedragonhernandez/media/IMG_20130715_154522_zps2ebc86c6.jpg.html?sort=3&o=2 Edited July 15, 201313 yr by dragon123443
July 15, 201313 yr Author http://s1288.photobucket.com/user/josedragonhernandez/media/IMG_20130715_154507_zps14b8bf1a.jpg.html im sure i have it done the right way all knukonceptz kpolossus flex 0 gauge ofc
July 15, 201313 yr By looking at the picture, I believe those wires where some what loose, and that creates way more heat on the wires.
July 15, 201313 yr Author does it? i was told the exact thing at the shop.. when i removed them though they were really tight in that fittging except for the battery post its nearly impossible to tighten that one. i also dont know why that sliced wire turned brownish.
July 16, 201313 yr Yes, remember that there's a lot of current draw from the amps and if wires or connectors are loose or to small they will heat up very bad and melt.
July 16, 201313 yr Author i dont have a system installed yet dave is completley lagging it on my box it is pissing me off already. that wire that melted is 4 gauge that goes to a distribution block with 2 8 gauges those 2 8 gauges go to the fuse box under the hood
July 16, 201313 yr Author but ill take your advice im just going to order the fitting again along with a foot of more ofc 4 gauge wire and just try it again. do you think itd be better taking those 8 gauges out of the way and just running that 4 gauge wire straight to my fuse box? Edited July 16, 201313 yr by dragon123443
July 16, 201313 yr i dont have a system installed yet dave is completley lagging it on my box it is pissing me off already. that wire that melted is 4 gauge that goes to a distribution block with 2 8 gauges those 2 8 gauges go to the fuse box under the hoodAnd with no amps what are those wires connected to?
July 16, 201313 yr If that is how it was and you didn't unloosing anything. It's o vinous why it didn't work. The fuse holder that is melted, the wire just fell out or did you remove the wire and screw the nut back in? And the other block that looks like for 4 gauge and the wire was trimmed down and crammed in is no bueno. When you do the big three always leave the factory wires so that if something like this happens your vehicle is still functional.
July 16, 201313 yr Author Yeah I left it all in. This néw fitting licks balls my wires don't fit into it.The wires are just the ordinary big 3 just that I started off having like 4 wires to my positive terminal and this is what I did to work them all in
