Posted August 10, 201313 yr Hey guy's let me start off by saying im new to the board, im in the crossfire of buying a mojo 15 or sundown zv4 15, don't really know which is the hardest hitting sub between the two. I have a ford focus se (trunk type) and im debating on doing a custom box in the trunk or inside the car and remove the backseat. So im asking for some help on which sub is the best and the best way to build the box. This will be a single 15" build BTW. I will be using an extra battery, 0 gauge wiring, 3500 amp. Thanks Edited August 10, 201313 yr by Candyman Jr
August 10, 201313 yr i can see you did not read the rules.... and your asking to compare basketballs to footballs
August 10, 201313 yr don't really know which is the hardest hitting sub between the two. ThanksThis is all dependent upon box specs, driver specs, and the environment you place your driver and box in (ie your car).Have no advice for you other than sealed off facing forward from trunk seems to be the most recognized "loudest" trunk setup. And if the 3500 amp you are gonna use is a Sundown then get the ZV4 just to match.
