Posted August 11, 201312 yr 2007 Honda AccordPioneer 80PRSSundown SAZ1500Fully Loaded 12in FI BL2.5 cu ft box after displacement tuned to 34 hzAll 0g wire and Shruiken 1500 extra batt plus yellowtop up frontThe FS of the sub is 39.8 and i was wondering if there was any relationship between fs and box tuning? My main goal is SPL but I will use it as a daily driver so i dont want the sound quality to go to shit.
August 11, 201312 yr 2007 Honda AccordPioneer 80PRSSundown SAZ1500Fully Loaded 12in FI BL2.5 cu ft box after displacement tuned to 34 hzAll 0g wire and Shruiken 1500 extra batt plus yellowtop up frontThe FS of the sub is 39.8 and i was wondering if there was any relationship between fs and box tuning? My main goal is SPL but I will use it as a daily driver so i dont want the sound quality to go to shit. 2.5 @ 34hz should be good, if that is net volume and it has enough port area.
August 11, 201312 yr Author Alton designed this box for me in the spring i just never built it. Would i gain any spl with this box?
August 11, 201312 yr If you currently have 2.5 net tuned to 34 hz with 43 square inches of port area you should be set.
