Posted August 12, 201312 yr Hey guys!I’m wantingto turn one of my car subs into a home sub just for music and movies. I waswondering what’s the best way to go about this? I don’thave a box for the sub so I guess id have to get one made from someone off ofcraigslist.What kindof specs should it have or anything that I should have required done to thebox? Such as a port & air space. I’m notsure how either sub would work with the receiver I have.So pleaselet me know which sub you think would be best match for the receiver. I don’tknow much about this stuff so all help is appreciated.I do notwant to spend much this lol.Thanks! What I haveto work with:- AlpineType R 12” Sub - Model SWR-12D4OR - Alpine Type S 12” Sub – Model SWS-12D4 - As a receiver I haveDenon AVR-3803 Receiver - I have two computer speakers that I am happy with, as they are veryloud. More info On The Type R Sub:http://www.bestbuy.com/site/Type-R+12%22+Dual-Voice-Coil+8-Ohm+Subwoofer/6566948.p?id=1218754580823&skuId=6566948&st=SWR-12D4&cp=1&lp=1 More info On The Type S Sub:http://www.bestbuy.com/site/Alpine---12%22-Dual-Voice-Coil-4-Ohm-Subwoofer/4769785.p?id=1218524494220&skuId=4769785 More info On the Receiver:http://www.crutchfield.com/S-QTtj74SyA1A/p_033AVR3803/Denon-AVR-3803-Black.html#overview-tab I know thismay not be the correct forum but I figured it’d be the best place to postsomething like this on considering it’s a car sub!
August 12, 201312 yr You will need a sub amp and a box. Neither of those drivers are particularly well suited for home audio and IMO you'd be better off selling them and buying something that is, but it doesn't make it impossible.
August 13, 201312 yr i have a ascendant audio atlas 15 that needs reconed, it would make a perfect home audio sub,
August 14, 201312 yr I had a SWR-12D4 hooked up to my sub channel off my Logitech X540 surround sound and it sounded very good in my basement. It was in a 2.5ft^3 box tuned at 33hz made out of particle board for pretty cheap. If it was powered by a proper amp Im sure it would sound even better. Good luck.
August 15, 201312 yr I used to have 4 of the first Gen Type R 15" drivers in vented alignments for a H/T sub stage. They actually sounded pretty good. They were different then the ones you have though. You would probably be better off selling what you have and buying a sub geared more towards your application, as already mentioned. You can get a really good 12-15" driver for around $150 and a decent plate amp for about the same... If you haven't built a lot of boxes you can start with a simple sealed alignment... Idiot proof most of the time...
