Posted October 4, 201312 yr First off, where to buy lead wires, from terminal to coil, and second, what to seal it to the cone with. And oh yeah, how much slack should I leave? I was going to try to match the working leads.
October 4, 201312 yr looks like you can get some on ebay. google tinsel leads. what are you sealing to the cone? i would assume you solder the lead to the coil and use some epoxy keeps things secured to the vc former, which would keep pressure off the solder joint. Edited October 4, 201312 yr by lithium
October 4, 201312 yr Author I meant where the wire passes through, but I can use epoxy for that too I guess
