ItItem(s) for Sale: 250 amp dual rectifier GM alternator. Its currently installed in a 95 camaro with an lt1 . cs144 large case. You'll have to check and see if this matches your application. I wont be responsible if it is incompatible with whatever you are trying to install it on.
Item(s) Description/Condition: Ive been using it for a few months and have had 0 issues with it. I'm going smaller though and wont need it anymore. Its just like this  http://alternatorparts.com/Extreme%20Duty%20Dual%20Rectifier%20CS-144%20type.htm but the fan is different. The fan make zero difference according to my local alternator guy though. I drilled out the threads on the top of the bracket to work with my stock brackets.
CS144 Series 250 amp Extreme Duty Dual Rectifier Alternator
Price: 200 plus shipping and handling
Shipping and Miscellaneous Item Information: If itll fit it will go in a usps flate rate box. paypal only, no echecks.
