Posted November 15, 201311 yr Just woundering what's a good eq for my set up plan on running a ipad mini for the headunit...eq? ??, amp is a bc2000, 2 orion hcca 15.2, crescendo 1100.4, 4 pwx 6.4 and 4 Ft1 tweets. What will be a good Eq. I was thing about a audiocontrol three.2...waiting on my most of the items...as well a crescendo battery Edited November 15, 201311 yr by antoinez28
November 15, 201311 yr Going to need a lot more than that. Your setup sounds VERY confused. The FT1's and PWX's do not blend together nicely at all. You will have HUGE gaps in the frequency response. Also using 4 FT1's is absurd. Even if you go forward with the PWX's 2 FT1's will embarass 4 of them. Adding the second ones will just be a net negative. You need a crossover AND eq. An eq won't do shit without.
