Posted January 21, 201412 yr Hi everyone please any helpHow do you wire 2 dual voice coil subs that are 2 ohms and i have a 2 channel amp ( http://www.amazon.com/Lanzar-VIBE2102N-2-Channel-MOSFET-Amplifier/dp/B00BN7XQG4 ) i want to know how to wire them up to the amp at the 2 x 2400 Watts @ 2 Ohms RMS i have come across this page http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_2ch.jpg%C2'> but does that mean that each sub is wired for 4 ohms. Any help maybe i am missing something or its something so simple but this is my first build and the subs are 2 12" Fi BT series and this is the only amp i have for now. If this amp is not adequate after help with the wiring i would love to know any good deals on amps that could power these subs any help would be greatly appreciated.
January 21, 201412 yr Wire the subs in series an have one per channel.I highly doubt that amp does rated power aswell
January 21, 201412 yr Wire the subs in series an have one per channel.I highly doubt that amp does rated power aswellThat will give him 4 ohms per channel he wants 2 ohms. Which can't be done. It would be 1 or 4ohms.
January 21, 201412 yr Wire the subs in series an have one per channel.I highly doubt that amp does rated power aswellThat will give him 4 ohms per channel he wants 2 ohms. Which can't be done. It would be 1 or 4ohms.that is correct.I would get a dif amp
January 21, 201412 yr use this link http://www.the12volt.com/caraudio/woofer_configurations.aspI don't need it I was agreeing with the 4 or 1 configuration. I would find a dif amp or series subs use 1 CH .DO NOT BRIDGE
January 21, 201412 yr Author so for now that being the only amp and i know its not rated and will push what it says i need to find a better amp that will push em harder so i guess i will just wire them i i should have got the 1 ohm subs but live and learn right thank you everyone for your help if you got and suggestions of any amps to buy online to power these subs perfectly i would appreciate it!
January 22, 201412 yr Author what about two of these - > http://www.sonicelectronix.com/item_68830_Pyle-PLAM3601D.html%C2'> one for each sub?
