February 25, 201412 yr The PWX is NOT capable of playing ANY midbass. It will REQUIRE a 3 way. 3 way active installations are not trivial. And no way in fucking hell can you pull one off even reasonably with amplifier crossovers.* *excluding amps that have full built in digital processors
February 25, 201412 yr So everyone tells you there not for your goals or setup but you still insist on purchasing them. If that's the case then go ahead and buy them since none of the advice given was considered.-Edit- Edited February 25, 201412 yr by SpeakerBoy
