Posted March 2, 201412 yr Here is a video to show my new charging system. The main point of the video, which came to my surprise. But EVEN with a large electircal system, you still may not be supplying enough for your audio equipment. This was an interesting find for myself. At full tilt sort of speak, my vehicle, the vehicle itself, pulls right around 40 amps!!! That is HUGE! haha. That included, headlights which is H.I.D.s, which pulled 10 amps lol, Wiper Full blast, Front heat full blast, rear heat full blast, and interior lights on. So, let's just say I had an stock 80amp Alternator. That means 40 for the vehicle, and only 40 for the audio equipment. That is some huge information to know for your installation. Luckily, in my case. That 40 amps is pretty not existence after the front battery, as you can see in the video. But then again, there was no load from the rear battery bank. Just neat numbers to have.
March 2, 201412 yr Here is a video to show my new charging system. The main point of the video, which came to my surprise. But EVEN with a large electircal system, you still may not be supplying enough for your audio equipment. This was an interesting find for myself. At full tilt sort of speak, my vehicle, the vehicle itself, pulls right around 40 amps!!! That is HUGE! haha. That included, headlights which is H.I.D.s, which pulled 10 amps lol, Wiper Full blast, Front heat full blast, rear heat full blast, and interior lights on. So, let's just say I had an stock 80amp Alternator. That means 40 for the vehicle, and only 40 for the audio equipment. That is some huge information to know for your installation. Luckily, in my case. That 40 amps is pretty not existence after the front battery, as you can see in the video. But then again, there was no load from the rear battery bank. Just neat numbers to have. Yep you have to consider all the cars electrical draw as well as the amp or amps.
March 2, 201412 yr Author Here is a video to show my new charging system. The main point of the video, which came to my surprise. But EVEN with a large electircal system, you still may not be supplying enough for your audio equipment. This was an interesting find for myself. At full tilt sort of speak, my vehicle, the vehicle itself, pulls right around 40 amps!!! That is HUGE! haha. That included, headlights which is H.I.D.s, which pulled 10 amps lol, Wiper Full blast, Front heat full blast, rear heat full blast, and interior lights on. So, let's just say I had an stock 80amp Alternator. That means 40 for the vehicle, and only 40 for the audio equipment. That is some huge information to know for your installation. Luckily, in my case. That 40 amps is pretty not existence after the front battery, as you can see in the video. But then again, there was no load from the rear battery bank. Just neat numbers to have. Yep you have to consider all the cars electrical draw as well as the amp or amps. Yessir
