The remote mounted dial on a big sub power amp? Never had a amp with this? Isn't it the same to just turn the sub up or down threw the head unit?
Thank you guys
it is a remote gain so you can lower the subwoofer output separately of the front stage. not all headunits have sub level control which does the same thing.
That and it's also nice to use both if you need to do a lot of attenuating with high output setups.
i'm surprised you dont see a mute button on the remotes.
