Posted May 26, 201412 yr Had one sitting for 4 years thought the motor shifted finally took it apart. The coil had hard bottomed a couple of times and put a lip on it. Any venders here make a kit? also would it be it be feasible to recone into a 18" http://fixmyspeaker.com/product/18-6-spoke-frame/ would this work? thanks.
May 28, 201412 yr contact psi and fi to see what they can do if you cant find a DD recone. Edited May 28, 201412 yr by lithium
May 28, 201412 yr Author Yeah.. I had hit up psi waiting on a response. Hit up dd also, it is cheaper to send it to them and have it rebuilt verses them sending me a kit. crazy.
June 10, 201412 yr Author Send it to DD. They should be able to rebuild it like new ! got a quote from corey dean. I contacted dd and it would be cheaper for them to build, than to by the kit. I wanted to diy.
June 10, 201412 yr Author I'm having fun with it this is a learning experience. If I bought rebuilt transmissions and engines I would not know what I do now.
