Even if you can't find a LOC a simple voltage divider will work perfect.  All you will need is a pair of 20 cent resisters to knock the input voltage to the amp in half which will probably be perfect.  You already know the input impedance of the amp so it is pretty easy to design and build, I will walk you through it through email if you would like, no problem.
